Ltspice 8390 for Automotive Application
Donnieclark
Tuesday 17 October 2017 - 08:19:25 Citovat
Uživatel #5142
Příspěvků: 2
Hello Everyone,
I am currently working on a project where, I have to measure the voltage and current at the load connected to (ECU) Electronic control unit in a truck.
The battery Voltage Vin (12V- 48V) has to be varied . The input from the battery will be given to Switch mode DC\DC regulator IC (which I have to choose, whose input and output voltage range is well within the range of 4V-50V. And it can measure the current or has current limit upto 12A. I have looked for many IC from TI and also from Ltspice (found a few for e.g Ltspice 8390).
The question is I too wish to use micro-controller to control the output voltage.
I am bit confused, as too what IC with sub components I use to design my project.
Any Idea , Suggestions would be appreciated,
Thanks,
I didn't find the right solution from the internet.
References:http://www.electro-tech-online.com/threads/ltspice-8390-for-automotive-application.151503/
whiteboard animation
Vygenerováno za:0.2307 sec,0.2049 z toho dotazů.
