Electric Parking Brake Module
Donnieclark
Tuesday 17 October 2017 - 08:18:37 Citovat
Uživatel #5142
Příspěvků: 2
Hello Everyone,
i had my EPB module burned, when i jumped the motor wiring to adjust the cables. At the first time had i hit the right polarity, it has moved, but the wrong way. Then i turned the polarity, but forgot pull the shoes off from motor to PCB...the motor works, why not, but the circuit board had also smoked. Fail.
I screw my own vehicles myself 99% without any problem, i had the module also disconnected, but not the platine. I say always: "Learning by doing", but the microelectronics is not my playground.
The both MOSFET had i indentified, there are automotive quality IRFR4104 N-Channel SMD-s, but there are also 2 smaller IC-s burned with 6 feets, i don´t know what they are, every help comes good, you are the experts. And can be also, than this a multi layer board is.
Any Idea , Suggestions would be appreciated,
Thanks,
I didn't find the right solution from the internet.
References:http://www.electro-tech-online.com/threads/electric-parking-brake-module.151567/
whiteboard videos
Vygenerováno za:0.1444 sec,0.1190 z toho dotazů.
